That's close enough for me
If I'm honest the last time I handled a conduit bender was 2007 and probably the last time I got involved with wire and tube factors too
'Capacity' and ease of installation are two rather different things!We'll have to differ on that one, the capacity of a 20mm conduit is about 10 from memory, ...
Maybe. My personal experience (of 20mm conduit) is very limited. However, my experiences of getting cables through relatively massive ducts/pipes (50-100mm diameter) is that adding additional cables can be anything but a trivial exercise, even if there is vast amount of 'space' ('capacity') available for the additional cable)s).adding a second set of 3 in a short straight run such as OP. one would hardly notice the initial set
Oh yes definitely,'Capacity' and ease of installation are two rather different things!
I doubt anyone who runs wire/cale in tube would say anything differentMaybe. My personal experience (of 20mm conduit) is very limited. However, my experiences of getting cables through relatively massive ducts/pipes (50-100mm diameter) is that adding additional cables can be anything but a trivial exercise, even if there is vast amount of 'space' ('capacity') available for the additional cable)s).
I have the T Shirts. On one job the customer decided their own staff could pull the cables into the 100x100 trunking far cheaper than our quote, after wiring up and testing to find faults I discovered they had blown a thin draw line in then pulled in a 6 or 8mm draw rope for the 4 bunches of five 4mm² singles (4x 3ph+N+E) using the forklift something approaching whole 100m drums. We were glad we didn't have to foot the bill to replace them and the damaged existing cables.Yep, pull plastic covered in too fast, with others in place, and the friction can melt and glue themselves together.
Maybe - as I said, I have very limited personal experience of using 20mm conduit.I doubt anyone who runs wire/cale in tube would say anything different ... However in the case of so much spare capacity created by 3 2.5mm² singles on a 20mm tube I believe my comment holds up.
Me tooI have the T Shirts.
... or conduit with conduit drops?All of the above are the reasons trunking with conduit drops is the most appropriate way to install this.
Horizontal conduit runs with Tees would be a nightmare. Any future alteration would require all cables to be removed from the section of conduit.... or conduit with conduit drops?
Although I agree wholeheartedly one has to consider what the wire lengths are and chances are of future alterations.Horizontal conduit runs with Tees would be a nightmare. Any future alteration would require all cables to be removed from the section of conduit.
In my 46 years in the trade I experienced the heartache. Believe me, trunking is the way to go.
Plastic trunking light as. Pulling in cables easy peasy, just the drops to worry about.Although I agree wholeheartedly one has to consider what the wire lengths are and chances are of future alterations.
One brick structure (used to be a coal shed) 0.8 x 1.4m on the side of the outside toilet the same size I installed plastic conduit for light, switch and a socket which was pretty much only used for the lawnmower, the toilet only had a light, switch & FCU. Chances of further change? exceedingly low, length of wiring to be removed if required? way less than 2m. Difficulty of fitting trunking Vs difficulty of making alterations? let's say 5 Vs 1.
How about buy a roll of T&E and a roll of G/Y. strip the 2 insulated conductors out of the T/E and run singles with the G/Y in the conduit?
OR get 25mm conduit?
Oh yes, and he did say a domestic garage which is a little bigger than your dimensions and more likely to need modifying at some point. Lighting cables can also be put in the trunking saving further heatbreak trying to fit conduit all round,Although I agree wholeheartedly one has to consider what the wire lengths are and chances are of future alterations.
Yes I know and incase you didn't realise your response was to my comment starting with this:Oh yes, and he did say a domestic garage which is a little bigger than your dimensions and more likely to need modifying at some point. Lighting cables can also be put in the trunking saving further heatbreak trying to fit conduit all round,
The example I gave was to highlight a situation where alteration was unlikely and length of wiring was so insignificant along with ease of removing it if such a situation were to arise. The complication of adding trunking (as it happens in that scenario it would have been a lot of additional work cutting appropriate holes through the shelving arrangements) , drilling it to take conduit adapters etc would have been crazy amounts of additional work for absolutely zero gain whatsoever. In a garage sized workshop my assessment could very likely be different.Although I agree wholeheartedly one has to consider what the wire lengths are and chances are of future alterations.
