Thinking about buying a wall chaser to cut a channel in my concrete floor so that I can run a replacement pipe for one of the radiators.
I found this one:-
http://www.screwfix.com/prods/81200/Power-Tools/Grinders/Erbauer-ERB125Y-125mm-Wall-Chaser
The method of varying the depth is obvious enough but how do you vary the cutting width?
Do you stack cutting discs side by side on the unit or something?
I found this one:-
