Dear members,
I am trying to install a wall shower in downstairs w/c. I have got the shower area set up (yet to be tiled) and I am trying to use the existing hot/ cold water supply of the sink for the wall mixer shower. I am not interested in electric shower as they don't give too much of water flow.
I have 2 issues at the moment.
1. Since I am going to splice the existing pipework from sink for hot/ cold water, can I have a wall shower where the supply of pipes goes into the top of shower or bottom as my pipwework cannot come from behind the wall to fit into wall showers? Can you recommend someone who does such showers? Tried to look into e-bay and screwfix but no luck.
2. I have a Gravity based Hot Water and Pump based central Heating system which works just fine. In 1 or 2 years time, I would be going for Combi Boiler. So I will need the shower with a tap as well for now as I believe I won't get much pressure. Generally mixer showers run off combi boilers with min 1 bar pressure. Mine is going to be fed with hot and cold water tanks.. So ideally I need a wall mixer shower with tap outlet and one that can work with low pressures as well as high...
Any recommendations/ questions/ suggestions/ answers welcome
Thanks in advance..
Thanks in advance..
