Wall mounted sink on plasterboard wall?
You havn't said whether you will be re-tiling. If you are then just do as suggested and cut the plasterboard out, fix some battening where the basin fixing points will be then cover in ply.
You havn't said whether you will be re-tiling. .
No, I won't be tiling.
There's currently 1930s thin pine vertical planks of paneling covering the walls of the bathroom.
I'd like to keep the original paneling.
So I imagine it's a case of removing the paneling, doing the work as stated earlier in the thread, then re-applying the removed panels.
