I had new light fittings installed a couple of years ago. The engineer confirmed it was a ring circuit then - through each fitting is an additional live connecting it to the light in the next room. He actually muddled them at one point so that switching the light on in the bedroom actually switched the light on in the lounge. This is what I understand to be a ring circuit. He said he'd never come across it before.
No not a ring, that sounds like a totally standard installation,just like 99.9% of properties.
The symptoms of the 'error' you describe could not possibly occur if it is a ring.
