You dont tooth below DPC
DPC level is the datum you work to and you gauge your new work down from this so that when you build the wall up your last course ends up level with the DPC/course on the existing house
You obviously also work to a vertical line. It may be that the new wall needs to be in a specific place and so you make do with whether it lines up to existing perp joints or not. Sometimes you can move it slightly so that it lines up better
You also work out what course will be the toothed course and set the wall out so that you start with a full brick or a half down in the footings
