I suppose that if there is any chance of something becoming dangerous then good old health and safety has to take a priority............
Any gas boiler fitted on a sealed system must have a form of overheat protection.
And in the past it was not un common to have to order an additional kit for boilers when being made into sealed systems incorporating overheats and some form of pilot interupter
In actuall fact it is still avialable on baxi back boilers that are still in production and if done a little further searching i would say there are several other boilers out there that still use it.
So still a present day thing and a totally approved practise.
What trick would it be? its all manufacturers approved parts for there bollers
NA still C or D but obviously a limited market to where they can be fitted now.
To WDIK
I turned the pump down on advice from the diynot site and it seemed to improve the circulation for a while ie the rads upstairs started to get warm and hold their water. Then we had a disaster in the spare room with a washbasin tap fracturing. As it was late at night and we couldnt get access to the loft very easily so we turned all the taps on in the house so that the tank could not fill as quick as it would empty in order to make the repair, which was a success. Since then despite the pump being on lowest the air is back in the radiators. Wil try the lockshields first before the magnet test
absolutely, if you are not sure, don't do it.
it is just that some posters make comments that are not far off the mark, but enough to show they are actually not corgi registered.
no RGI in his right mind would convert a system from open vent to sealed without checking the boiler can handle the pressure, so that is a bit of a no-brainer.
to state that a boiler without an added overheat stat would be classed as Immediately Dangerous is total poppycock.
apart from that, i have never heard of a boiler where the manufaturer specifies that you need to add an overheat stat upon conversion to sealed.
admittedly, i have not seen every model that was ever installed.
