Warning: I got sloppy.
I still prefer my idea of licking them
Fair enough, but that's only really necessary with ELV!
In passing, I don't recommend trying it (a battery) with your tongue (which comes 'pre-licked') - a distinctly unpleasant experience, albeit as much to do with electrolysis and chemistry as 'electric tingles/shocks'!
Kind Regards, John
No, you wouldn't. You would have felt nothing at all. As you were insulated and not touching anything else, you don't feel anything at all. In the same way that birds can land on 400kv lines and don't even notice it.
I'm certainly not recommending that people go and try it!! But nothing actually happens if you are not making a circuit.
Actually, you'll very rarely find birds sitting on 400kV lines - It's exceedingly painful for them. Corona is a big problem on EHV lines which power distribution companies to go great lengths to minimise by making sure everything has smooth rounded edges. Birds have pointy bits on their anatomy that create very strong electric fields in those areas.
Birds will rarely sit on anything above 132kV lines
Whilst, as this case illustrates, it probably should be the case, I'm far from convinced that even the initial testing of a new installation would involve checking of the polarity at every socket. That certainly had not been the case with PIRs/EICRs I have seen done on existing installations.
Kind Regards, John
Sorry for the late response!
I actually insist on it for new installs, even if I've done the work myself. It takes 10mins to plug an mft into every socket in a house and check that you get a reasonable r1+r2.
Next you'll be telling me some people don't do all the tests required for ring finals. :eek:
I guarantee you there are people out there taking money by pretending to be electricians who don't even know what the tests are.
