No I didn't mean that! Warm air has to be humid (which means it has to be carrying moisture) in order to condense on cool surfaces, once you start warming the wall, moisture from the wet surfaces will obviously start releasing from it and get carried away and by warm air currents which will also heat your felt, and if you ventilate the loft space to outside, moist air will escape carrying any moisture to outside.
Dry warm air does not have high moisture content, and so it would remove more moisture from the wall and vent it out. The hot air heats up the wall and the space in your loft, escalating evaporation and so it drys fast.Humidifier would also take fair amount of energy and not be as fast as warm air blow drying.
Only thing is he will have to make a way of removing moist air to outside, through the eves or use a an extractor fan (like the ones used in bathroom) and flexible ducting to vent moisture laden air to outside. or alternatively wait for summer by which time his walls could be covered in mould.
