Washing Machine and Tumble Dryer sharing same waste pipe
You right Hugh Jaleak, 36mm external - 32mm internally. Damn, so I am in a poop and can't connect washing machine? Is there a way to bypass that by any chance?
But tumble dryer ok? It does not require massive output...
BTW, is it possible to connect waching machine waste to the toilet waste pipe (I am just desperate to leave washer in that damn toilet room so it would not use up so much space elsewhere)?
Washing machine is fine to discharge to WC drain, main issue is how to connect it..... Depending on how WC is currently connected to drain will give you the options, but usually a suitable pan connector with a 40mm boss connection would replace current WC connection to the drain and provide you with a connection for the proposed waste pipe.
Many thanks Hugh for advice. Found some pan connectors, now have to find proper one with 40mm boss connection, as most of them are 32mm. WC is 90D bent, so have to find similar one but with additional connection. Thanks again!
