A neighbour called me in to fix her Bosch washing machine after it done a wash cycle but did not spin dry her clothes, and when she tried to run the machine again, it simply just did not run at all, although it had drained all her water, but the clothes were soaking wet.
So the first thing I checked was that her main pump was nnot blocked, and it appeared free of any blockages, except for the normal muck that you see lined up on the internal pump housings,
So I then removed the top cover, took out the small tube from the pressure switch, and tried blowing through it, and I met a lot of resistance, so I knew the tube is blocked up badly,
Unclipped the entire rubber hose aseembly that connects the drum to the pump and feeds the tube for the pressure switch, and there it was all gunged up with slimey smelly stuff, felt like silicon mould! but much softer in feel! after clearing up all that mess, and refitted the rubbers back, the machine is perfect since.
She is quite happy about it now as she almost went ahead and bought a new machine as she thought this one has given up the ghost as she has had it for nearly 5 years, and then I told her my current washing machine is a Zanussi turbomax, and is nearly 21 years old and still going strong!
Edit: Looking for someting I just found the original receipt for this Zanussi washing machine, bought in 1991 July, for GBP.430.00! no wonder it is still going strong since the more you pay the more durable the product!!
In all that time, I only had to change the rear hall effect sensor on mine! and may be a switch on the front that went bad, apart from that it is still with its original drum, bearings, and all else. even the belt has not been replaced in all those years.
indeed people like me are the enemies of wheel of ecconomy! lol
I rathyer grind the wheels of ecconomy rather than the wheel of ecconomy grinding my ass.!
