doesn't matter what the manufacturer says connecting it straight to a drain poses a catergory 5 fluid risk (potential contamination of the mains water supply) under uk water regulations.
tee in a hepvo trap to the waste and fix the watersoftner discharge so it is 20mm above the inlet.
I normally use a munsen ring and backplate attached with some studding to fix the pipe above the waste
qoute
"The drain is connected to the drainage system which is a backflow risk in fluid category 5. Clearly the prevention of possible backflow of sewage into the water supply is of paramount importance. The requirement for this connection is therefore an air gap which must satisfy the Regulator’s Specification"
Fluid Category 5
Fluid which represents a serious health hazard because of the concentration of pathogenic organisms, radioactive or very toxic substances, including any fluid which contains –
A HepVo trap with an appliance spout on top would be better than nothing if you can't get it with a proper air gap but still incorrect (HepVo traps are very reliable though).
I'm hoping someone can help me with a little fitting help.
I.
Except I can't work out how to connect the waste pipe. Not sure if all water softeners are like this but the tubing is about 12mm (OD) thick (about 9mm ID).
Well the one I fitted @ my last house had that thick walled hose so I guess it's so it can't go on a w/m connector on a trap . Yes I used a standpipe and trap
