- Joined
- 12 Apr 2020
- Messages
- 466
- Reaction score
- 0
- Country
Couldn't agree more, always soldered copper wherever possible .... brass compression where it's hidden with no easy access .... personally I would avoid. One slight twist the wrong way then could be left with a leaking fitting where it can't be got at.
Not sure if the OP is using copper or plastic tho.
@robodelfy, when you then come out of the wall leave enough length so it can bend upwards before the valve and then add a pipe clip at that point then an ISO valve and then add another clip above it so you are clipping and supporting the valve and the pipe above and below.
Thanks I'll do that for where it comes out of the wall
As for the pipes, it's mostly copper, but I'm changing to plastic for where I'm running it into the wall, because it's a DIY job. I've also had a plumber over who said that would be fine. I am a little worried after your comments, but it seems push fit plastic fittings are used frequently under floor boards and hidden. Like the over 20 year old one I revealed which is fine. I know that's just one case.
I'm also fitting the little clip/collars on all fittings so apparently they can't come off then....or it provides a lot more security
