I have a Glow-worm fuelsaver F boiler, Myson Aerjec auto-venting thingy and a Honeywell MPV which is stuck in the mid-position. There is also a manual bypass valve. With the boiler stat set on 2 (out of 6) and with the bypass valve almost shut the water boils up through the Aerjec vent. With the bypass open too far the H/W and rads don't get hot. Should I have to control the water temperature this way? I've just bought a new boiler stat (£40+ ) but haven't fitted it yet. Is that likely to cure it? I thought the boiler stat controlled the temp of the flow water, not the return?
Can anyone help please?
