I helped a friend last Thursday to replace a fibre pump washer
sounds like a double handed job
Would it be outrageous to suggest that some fibre washers are rubbish and some are fine? !!
Tonybhoy - I don't do enough bogs to know the washer you're on about. Got a pic?
It's usually neighbours who want free plumbing on a Sunday who come to me for bog stuff...
Yes I know that even though I've only changed a few. A hundred or so I suppose. Not so far had trouble with one leaking though.dia said:Chris, a lot of the brass ball valves are designed to take a nut and olive, so the tail is tapered and has very little surface area for a the washer to seat.
It seems that you don't know how to do an image URL either.Sorry don't know how to do a screen grab
Is this what you meant:
Yeah I've never see those fail, and even if one did the 'leak' would be contained and simply overfill the cistern.
I don't see how a leaking washer could flood a bathroom unless the cistern lid is missing, or the overflow height is incorrectly set, or, in the case of an external overflow pipe, a cracked pipe or leaking joint.
