water in me rads but not boiler
21 Jan 2004
hi' drained and refiled but no water in me boiler ..tried bleeding pump water there...theres a drain valve in the pipes behind the boiler but it wont spit any water out. shone a torch up there and you can see the valve moving. also theres a strange looking valve in the same loop dunno what it is or does? any help...am i draining it right in the first place ?
solid floors with a loft conversion..
indirect ..gas...s plan.. thanks..
what boiler you got and does the pipework rise from boiler or drop?
hi' its an ideal w2000..the boiler is above the cylinder and pump...the pipes rise into the roof space .but there is a loop with a drain valve in that seems lower than the boiler but i cant get any water from it...
being supid i drained the cylinder and the offending radiator..
in the loft there are 2 vertical bleed pipes which i've done and water comes out... i just don't understand how i can get water back in my radiators but not in the boiler.
the loop seems to be on the lower pipe from the boiler ..any help ?
yes.. there appears to be an unusual drain valve in a loop just below the boiler and also a normal drain in the same pipe..neither of these will let anything out..
my friend has a vacuum pump. is it ok to use it on the drain below the boiler ?
