so these doors would always need a strip…which goes back to my original point.
No, usually the font lip would be inclined slightly away from the door, so water would drain out rather than in.
I would suggest that the vast majority of garage doors fitted across the country don’t rely on a seal to keep water out. They rely on the correct falls to the garage to drive interface so that water runs away from the door.so these doors would always need a strip…which goes back to my original point.
Did your up and over door prevent any water ingress?
I was under the impression that garage floors HAD to have a fall to the front?
However a builder may not follow rules, and driveways sometimes fall towards the door.
Certainly my house is slightly on the crest of a bend and the houses behind me are considerably lower down.
This means that my pavement is maybe 4" higher than at the garage slab over 20 feet.
This is a new double garage, maybe the concrete in the old garage with the up and over sloped away as it should.The OP has already suggested there was no ingress problem with the up and over door, before the new door was installed - which I find hard to believe.
I find it impossible to believe .The OP has already suggested there was no ingress problem with the up and over door, before the new door was installed - which I find hard to believe.
