Is it me or does anyone else think the caleffi combination valve is facing wrong way,i know it could be right as we cant see inlet into cylinder ,but i would have fitted it differantly?
I thought that to start with, then realised it's probably just the tapping for filling loop taken after the control group - if it was back to front you shouldn't get anything through it.
Thank you all for your replies to our problem.
We had a qualified unvented systems plumber in yesterday who did a full investigation of our system & checked all the valves.
He's figured out that it's the first valve we replaced, the 'expansion relief valve' that's gone again & he's going to replace that. We did replace the 3 bar pressure relief valve as a precaution as we had a spare part for that already.
Fingers crossed that'll be the end of this drama... thanks again for all your suggestions.
I know this is an old thread, but as an unvented installer for some years, another tip for future reference, is:-
If you have checked all the safety pressure relief valves, the expansion vessel could be undersized.
If it happened from day one I would be looking at pipe sizing the system.
Glad yours was the other alternative!
I said I had been doing it for some years, and I have recently added an extension, with shower room etc,...........my vessel could not cope!
