What is the name of the fitting I should be looking for to insert a pressure reducing valve under my kitchen sink, given that the pipe itself has an outside diameter of 15mm, *but* the pipe's screw fitting that I'd be inserting the PRV into has thread diameter 24.4mm-26.6mm (measuring the inside of the female connector's thread and the outside of the male connector's thread, respectively: I guess I'd call that one inch)? The most common PRV size options of 22mm and 15mm don't sound right, unless it turns out that there's some kind of convention that 15mm pipe always uses one inch threaded connectors, so "15mm" actually means a one inch connector and that's what I should go for?
Normally I'd just check the diameters matched at the hardware shop, but can't do that at the moment!
(Context: inserting this before the feed-off to the washing machine, along with a tee to an undersink filter which can't take my mains pressure.)
