I fitted a power shower some 3 years ago with a separate pump. The out put goes to the shower only. When we use the cold water(only) in the bath or sink the pump tries to switch itself on but in surges. At times it freezes completely as if the motor is going to seize up. It works perfectly well when shower is on..
I belive this is because the water is receding from the pump when we use other appliances (although it does not happen on the hot).
Can any one suggest a solution that does not involve re positioning the pump (in a difficult position with pipes under bath floor).
