Can't turn up on site with a tub of Vaseline.Vaseline. Already the right consistency.
Transfer it into a plain container?Can't turn up on site with a tub of Vaseline.
Yes you can - just pretend that you"re a plumberCan't turn up on site with a tub of Vaseline.
Do it at home / in back of van?No hot works on site.
We're not back to plumbers again, are we?Do it at home / in back of van?
Buy a hand plane then. I always have a nub of wax candle in my plane socks (which in my case literally are old singleton socks, in the main, which are well oiled and hold a plane each - complete with a bit of candle)It's just these candles I have, I want to use them! I may see what's on the shelf in the garage and put on my lab coat.
How are you going to fit the plasterboard if you are using 170mm screws.We've just been fitting some 120mm insulation board into the underside of rafters with some 170mm screws, so piloting was not an option.
The impact driver struggled a little if the screw was not waxed, the screw flew in when waxed.
But generally piloting is not always practical either
Not boarded. It's a large roof and eaves void, so insulation onlyHow are you going to fit the plasterboard if you are using 170mm screws.
I'm tempted to ask what you do for a livingScrew lube.....ky jelly
