Installed in 2004.
Serviced annually by the same man, OFTEC registered.
The burner is a Bentone
Black smoke started coming out of the exhaust about two weeks after the annual service in January.
Called the engineer, he replaced the burner nozzle.
Fine for a couple of days then black smoke.
Engineer came and said he had used a slightly different nozzle which is usually ok.
He turned the oil pressure up slightly and got the boiler to work ok with the same nozzle.
It was fine for a couple of days then black smoke.
He did not have the correct nozzle.
He came today to install the correct nozzle and adjusted the oil pressure.
It was fine for a couple of hours then black smoke.
Errr what next?
Errr what next?
