- Joined
- 20 May 2021
- Messages
- 120
- Reaction score
- 1
- Country
It's a mess, but if it isn't leaking leave it alone.
Thanks. Will reply to the rest of the posts as well and appreciate the input.
Not sure how a 90degree WC plan connector is going to create less pinch points then a WC bent flexi connector (if anything you can pinch and bend the flexi is there is blockage). Issues on the pantry side of the WC are easily fixable as easy access - its issues on the garage side which will be concealed under a raised floor and with a shower on top that we need to prevent.
... is there any kind of plumbers WC Waste Stress TEST that can be done? - i.e. shove a load of bog roll in one lump (or something) in the WC and see if it flushes it all away? - then you know its passes a stress test at this time (given that with the passage of time and debris built up / degradation of seals - that might change.).
