- Joined
- 27 Jan 2008
- Messages
- 25,092
- Reaction score
- 2,919
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
There was normally a 1A fuse fitted in the plug, so replacing with a 5 amp plug you would need to check if it needed fusing down.
For Mk at least the earth lugs were always sold seperate.They didn’t fit grommets back then.
Or earth links. Didn’t even have an Earth terminal in them old boxes
the clock plug has an unusually small fuse in it.
I don't know when electric clocks went out of fashion and battery Quartz ones came in
AIUI "long-term" averaging at 50Hz is a requirement of the DNOs specifically because of electric clocks.
In the same era (and 80s) I used them to supply lights above bookcases etc..In the 70's we used these 'clock points' for supplying mains power to indoor CCTV security cameras.
