What are the Security Grades?
Europlex, you know everything, or at least you try to give the impression that you do. Could you read the book you had the 'grade list' out of, and let the forum know precisely, when, where and by whom were these grades formulated. I should insert that I know the answer. Do you ?. By the way this post contains sixty two words.
...... then I suggest you do it, I'm not going to waste my time.
If there is a minor infraction, so be it.
I've obviously hit a nerve as usual. Never mind, I'll do a decent post for the benefit of visitors to the site so that they are in no doubts, since you can't answer the question.
Grades are defined in 50131-1, but they are based on the skills, knowledge and equipment that an intruder would/may be capable of using, from this, the type of premises where this risk may exist was developed by insurers or risk mitigators.
Hi redpis,
Well, at least you have given some detail, I appreciate you for it. However, I was hinting at the 'EN' part of the number. If you know what this stands for then let the previous poster know, since it is relevant to promoting his knowledge of the subject. Good post, well done.
