The reason the Intergas is so simple is that it is a backwards design. All other manufacturers have move to a seperate plate heat exchanger as it provides better hot water performance.
But entirely correct.
Plate heat exchangers are a more efficient method of transferring heat than warming up a solid block of aluminium and transferring through copper tube.
