Hi folks.
Posted a while back about the flashing on my garage roof which is split and leaking. It's an oil fired boiler flue. I've tried to seal it up with gutter sealant which worked temporarily but after a few heat cycles it goes again.
Some forum users gave great suggestions on replacing it, I'm just totally unsure where to order a replacement from and not sure I have the confidence to do it myself yet, I plan to ring that roofing superstore see if they can help, can anyone else suggest. It's 125mm diameter I believe. Also I think the cap is riveted and afraid to remove it as I may not be able to re attach it
A roofing company has quoted £140 fitted which I need to save up if going this route.
Can anyone suggest a silicone or sealant to seal it up with in the mean time to stop it dripping? Images to big to upload directly, as always the help is much appreciated.
[L]
[L]
