Im flumoxed. A plumber has recently changed both the heating element and thermostat in the immersion heater. About a week after the lady called me because the water was not getting hot. The plumber said it must be an electrical fault, so the lady called me.
I checked the element and thermostat and the new stat had blown. This was replaced. Due to the short life of the thermostat i checked the voltage at the stat 241v i checked the wiring was all clean at the terminals, i checked wiring at the switch everything was fine. The CU end showed no signs of loose connections and it had at no time tripped. The IR came in at 187Mohms.
Today i receive another call and the hot water is not working again. So assuming at this stage the thermostat or element has gone again what could be causing such short life spans of either of these parts.
Thanks in advance
Thanks in advance
