Home now, so have checked the stat with a multimeter. I'm getting ok readings on it. 00.8 on the stat tails.
The stat was set to 70°c. I measured the temperature coming out the bath tap, was getting 86°c on it. I've turned the stat down to 50°c and will drain the tank after a shower & washing up etc. Will turn it back on to heat at 50°c then test water temp again.
