Ok thanks, does that mean a cat6 cable directly from one router into the other or can it be, cable from router into RJ45 faceplate, RJ45 faceplate to RJ45 faceplate, RJ45 faceplate to router?
Either way will work. The thing to watch for is that there is solid core CAT6 and flexible core CAT6.
Solid core doesn't work too well with the crimp on plugs and the flexible core doesn't work very well with the faceplates. So decide which way you are doing it, as a first step, before buying the CAT6. The short flexibles are always used to connect the PC (or etc.) to the faceplates.
Solid CAT6 is cheaper than the flexible and faceplates are quite cheap, you just need a punch down tool, to connect to the back of the faceplate.
