What do I use to open this?
7 Feb 2012
I am trying to take off my TV from the TV bracket on the wall. However, there is some sort of security screw at the top and I have no idea where the key will be. Does anyone know where I can buy the key for this and what exactly it is called? Pic attached.
Thanks for your help.
You can get a security screw bit set pretty cheaply on amazon or pay a bit more for a quality product like wera
If you don't mind scratching it and it's not too tight you might loosen it with mole grips/water pump pliers.
Try a flat bladed screwdriver, offset it to miss the pin. If it's not too tight and you get just the right size, it can work.
