https://www.worlddab.org/public_document/file/442/DAB__Overview_2013.pdf?1394188480
Basically there are three/four delivery methods for audio.....
1 traditional FM radio
2 DAB
3 Internet
4 digital via your TV
DAB/DAB+ is delivered by radio, just like FM but on a higher frequency and delivered digitally. FM is transmitted around 100Mhz, DAB around 200Mhz, so different antennas are needed for each mode.
Internet radio requires access to the internet - either on your home wifi, or mobile phone data, but the internet allows you to listen to a massive range of 'stations' from anywhere in the world.
Digital via your TV, is delivered via digital radio, along with your digital TV channels - which usually involves a rooftop antenna for reception.
FM radio reception can be variable, depending on signal strength. It can vary from perfect to quite noisy. Digital tends to either work reasonably well, or not work at all. On or off with nothing in between, no gradual fading.
FM has some inaudible digital signal mixed with it, for various purposes, such as time and channel identification. DAB reception range tends to not be as good as FM. Audiophiles also suggest that the audio quality delivered by digital methods is not as good as the standards delivered by analogue FM delivery. Digital usually has the bitrate reduced to the minimum acceptable standard, to limit the bandwidth needed.
Finally, DAB portable battery operated radios absolutely eat batteries, when compared to FM radios. DAB radios really need to have an alternative supply to batteries.
