Less than 4, return trip.How many miles did you have to drive....?!
BoJo and Hand Job tell you to have a test, then make sure you can't "have a test".
Drive - in: no tests.
Walk - in: no tests.
Home kits : no tests.
So, on recommendation of friend who did same on Friday, went to local walk - in centre, for which you need appointment.
In all likelihood, I probably have a heavy cold but, as wife cares for young adults with disabilities, and I woke up at 0100 and was worryingly short of breath, I thought it best to get tested.
"By rights, I should turn you away as you are without an appointment", I was told at the centre.
I did explain that if been trying for two days, with no luck at all.
That, and me sweating like a robber's hoss, coughing, generally looking a bit spaced, and the fact that there was only three people in the queue, probably led him to take pity on me.
Like I said earlier, it's probably a cold but, following the advice of "get a test of you have symptoms" , I did so.
Perhaps, if they don't really want you to have tests, they could change the qualifying symptoms to exclude any symptoms that could be colds......
