Carried out a wiring inspection on a rental, the tenant was home, sitting with curtains closed watching TV, smoking roll ups, testing kitchen, no cooker just a microwave
Living their best life. Not.
I shall have to check who was the last person to do this particular tub because they transposed the lids on the chemical containers leading to me making a mistake.
I agree and suggested this when I first started but no one seem bothered. The containers are the same shape, colour and size but in the past someone has used a felt tip pen to mark the container and lid stating what is in them. The chemicals are compatible, in the sense mixing them together will not cause a catalytic reaction, but it is not recommended to dry mix them. They should be dissolved in the water. Rule of thumb ratio is around 10:1 I would have discovered the mistake when I took a sample of water for testing anyway but I happened to notice the one I was using was creamier than the one I should have been using.
I shall be emphasising my point again tomorrow before I leave on Friday.
Maybe colour coded stickers on both tub and lid would sort this out.
Maybe not decanting the contents into other containers would be the correct course of action?
No alternative to decant as they are supplied in 5 litre drums
I'm not arguing with you, only giving an opinion, so don't take any of this or the previous other than it is intended
I would not be surprised if the 5 litre drums are what your place buys in, and that these chems come in all sizes, from 500ml to 1000 litres.
You might be able to effectively have it bought in in "one-shot" quantities?
If they insist on 5 litre drums, some sort of trolley? Gotta be better than risking a chemical mix up through decanting stuff?
After all, while these particular chemicals might not be too risky to mess with (your previous post), it's not a good practice to get used to ; swap the chemicals with the same slip - shod practices, and someone gets hurt.....
