I finally got around to mounting the kitchen TV, on a cantilevered bracket. I've long been mulling over, how/where to fix it, on to a wall, or the side of a kitchen unit, and just couldn't find a good location, to get it off the worktop. Today, I got it in mind to hang it - but fixed hanging below a unit, hanging from it. It was designed with a two section arm, and the joints lacked enough friction to take the weight, and remain in the position set, so I redesigned it with just a single arm, but pre-pinned the arm position, by drilling and inserting a split pin. It now just swivels side to side, and tilts, but that's all that it needed.
Then this afternoon, I moved onto the mkII version of adapting the stair lift, into a dog lift. Just a piece of board with a metal bracket, so it hooks and latches in place, onto the stair lift foot rest. I managed to snap the first board Mk I, when I knelt on the unsupported end, and the dog was none too impressed with the board covered with foam, then a vinyl surface to lay on. Mk II, has a thicker, stronger board, with a support for the over hanging tail end, a ledge at the leading edge, to stop her paws getting caught between board and stair nose, foam and then covered with carpet.
