what is Sw on dimmer switch
20 Nov 2008
Leicestershire
I am trying to add a remote dimmer switch in place of single light switch in bedroom. I currently have 1 red, 1 black wire and the back box is earthed. I have the dimmer switch and it has a L connection, which i assume is live, I have a Sw connection which I have no idea of and I have the squiggle with the arrow which I assume is common.
Can anybody tell me what wire goes where please?
Andy
Don't the instructions tell you how to connect it? My guess would be to agree with yours ref the L , & the squiggle with the arrow through it is the variable output of the dimmer. The red wire should be live & the black is the switch wire ( under normal convention) & should be connected to the squiggle.
We sorted this for someone else about 3 months ago, cant remember the thread though.
Indeed you should have the details with the instructions. Otherwise you could help by revealing the supplier, make and model of the dimmer.
L is permemant live, the squiggle thing is switched live, SW is for a link to a slave switch. If its varilight.
The instructions are useless, looks nothing like the real thing!!!
It was from B & Q and is a getplc (make) model number is 517184 or GU6212RBBN.
Thanks for looking.
Google says it's a 400W 1 gang 2 way dimmer. Can't find instructions but I'm agreeing with Steve on this and the Sw is probably to connect to a slave for 2 way. So ignore the Sw terminal, put your red wire in L and the black (Which should have a red sleve BTW) in the squiggle. If it's metal and has an earth terminal you also need to earth it.
Yes, I can scan them, no problem. What I might try first is to take the unit back and swap it in case it is faulty!!
Andy
many thanks everybody..
I took the unit back to find it was damaged, I got a replcement and it worked first time.
Andy
