You should try drilling into old properties bricks with a cheap cordless or hammer drill.SDS and bricks = sledgehammer + nut.
What makes you so sure that I've never done such a thing?You should try drilling into old properties bricks with a cheap cordless or hammer drill.
You'd be burning drill bit after drill bit.
It's not the brick that changes with age, it's the kind of bricks they used at the time that is a lot harder.Bricks don't change much with age, a new Accrington brick is always gonna be much tougher than an old LBC red for instance.
The fact you mention a sledgehammer and a nut made me think that you were saying: "using an sds on bricks is the same as using a sledgehammer to crack a nut"What makes you so sure that I've never done such a thing?
Who says that you'll only ever drill into brick? I live in a stone district where it is often necessary to drill into various types of stone, one awkward one being what they often call Yorkshire flags, although I do sometimes have to deal with stuff like granite and high density concrete. Both the latter, and for that matter enginering brick, will defeat ligjtweight impact drills (i.e.combi drills) and require an SDS
