What is the best type of driveway?
The new guy from today said this. What are peoples thoughts?
(1) driveway will be flat with a fall to pavement for all surface water
(2) If there is a drain that is accessible, we would install a channel drain and outlet would connect directly in to main drain. As discussed on site, the best option would be to have a fall on the driveway for all surface water to run off onto pavement. This can be discussed in more depth on our second visit.
(3) This can be achievable, no problem
(4) We recommend tarmac driveways to be 100mm thick 60mm base and 40mm finish
(5) we would be using permeable tarmac which allows water to drain through naturally
(6) we excavate driveways to 250mm - 300mm
From finish hight. This will allow for a minimum of 150mm of type one build up base and allow 100mm of tarmac. If subsoil is really soft we sometimes excavate more than 300mm and install a geogrid menbrain for added stability.
I'm in Scotland and found this.
3:6:3
Still not clear if he can do this.
He said that in this area it is mainly all clay under the driveways so the soak-a-way will just fill with water like a bath and there is no drainage at the front of the house or even drain pipes on the front of the house so he can't use a drain. So his only suggestion was to create a fall so any rain water that doesn't seep into the permeable tarmac will drain into the street into the drain in road??
What do you think?
Ok in Scotland it is slightly different.
In your circumstances it will probably make sense to do what the contractor suggests.
Make sure your paving is far enough below the dpc.
Also if you don't want to install perimeter of block pavers it would probably be ok, just looks more attractive and is better for the finish
Thanks. I can't figure out based on skipping though the Scotland legislation if it is or isn't permissable to run surface water off a driveway onto a public path/road? Can you?
Can you think of any other options to get rid of surface water?
So many people neglect their block paving and then demonise it and move to tarmac etc. Actually it requires regular upkeep to ensure it looks good at all times:
- sweep with stiff brush every 2 weeks
- weedkiller regularly in spring and autumn
- pressure wash to clean algae
- brush in new kiln dried sand
- apply sealer and anti mould treatment
Etc.
Then it will stay looking good.
But if corners were cut in installation, mainly on the depth of sub base dugout and the base, then it will sink and that's the cowboy installers fault.
Tarmac if neglected will also get weeds, moss, sinking, crumbling surface etc!
Yes, intend to get Tarmac but this still needs maintenance too.
Just need to ensure it's not against any legislation to create a fall for rainwater to drain off it into the street for Scotland.
Permeable Tarmac? Eh?
Yes permeable tarmac.
I emailed the local council and asked them about if the driveway has a fall onto the public footpath for the rainwater to drain off that does not drain through the tarmac and this is what they said. Under my driveway it's all clay so a soak-a-way wouldn't work and there's no other options for drainage other than a fall. So can I ask what others would do in my situation? Here's council's response.
This is not something cover buy building standards in relation to drainage on to public paths and roads most local authorities do not allow it however it is not enforced buy building standards
