I would very much appreciate if there is somebody who has experience in cutting insulation boards and can give advice on what is the best way to cut them.
Even if I take perfect between the rafters measurements for a snug fit I cannot fit the board in. I cut it with a panel hand saw for general use. It's the right angle I struggle to achieve on the side.
Does it make a difference whether I cut down the shorter or longer side of the insulation sheet?
Do I need a circular saw?
Many thanks.
Many thanks.
