What is the point of these? They can't be used in a 115mm angle grinder as they spin too fast (normal speed ~11000rpm) and these are limited to 8500rpm.
https://www.toolstation.com/shop/Po...d1920/Abracs+Wire+Twist+Knot+Cup+Brush/p17385
To run these at the rated speed, they have to be fitted to a hulking great 230mm grinder (even some of these are too fast). And what then is the point of fitting a small cup brush to a massive grinder with associated large gearbox on the end..
It's fine with the twist-knot wheel kind, these are rated 11000rpm. Having fitted a cup brush to a 11000rpm grinder, I can confirm it's horrible.
Nozzle
Nozzle
