What Shower Pump?
Its a pretty standard shower head 10cm diameter
As for usage the pump powers hot water to the kitchen, bathroom sink and shower / bath on mixer tap and cold to shower / bath and bathroom sink - woudlnt say are heavy users.
Also if this was to be a problem - Would an electric shower work ok with this pump?
Marc
It's more down to the single use habits .... in other words, if someone is liable to use the shower for more than 10mins at full whack then they would probably run out of hot water, it's one serious pump that one. Quite a sight with a rain shower running at full bunna.
Nope, electric shower runs off the mains, cannot be pumped with that pump.
There are just 2 of us here - generally we
Don't have showers one after the other and usually wouldn't be 10 minutes so will hopefully be ok with this - thanks for all the advise!
full
(y)
It's something you can run with then Marc and adjust how you use it, you can always upgrade your cylinder later if needed.
