What size drill bit to get 2.5mm flex cable through masonry wall?
Drill a few holes in scrap wood and try cable first. Find size your happy with
Cable is is one from TLC
It says that nominal overall diameter is 9.8mm, so will either go with 12 or 14mm
Once the cable comes through the wall can I just use some silicone to seal the hole or do i need to use other additional protection?
Try to drill at a slight upwards angle from the exterior side so rain will naturally flow out of the hole.
Brickwork is rough and will chafe the cable so you should use conduit
The cheapest is probably the oval that's used for chases that will be plastered over, you can buy a length for about 50p,
Though 20mm round would be more elegant
I suppose if you had an offcut of plastic pipe handy you could use that
I find gradually working up in sizes is a good way to avoid blow outs, and once started to drill from both ends with each larger size. I don't mean trying to meet in the middle, but just about 20mm in from one end before working from the other end. If inside is lightweight blocks, plasterboard etc, then using a holesaw on that end is a good idea,then you never get the masonry bit chewing up the surface. And for direction, think about which side matters most, and which is the easiest to repair if necessary. e.g. plaster is easier to fix than facing brick.
16mm flexible conduit will take most cables you'd want to get through.
I'm fitting an outdoor socket. The outdoor socket is gonna be wired to a plug as opposed to being hardwired (spur).
Are you saying that after drilling the hole (cavity wall), a better job would be to stick 20mm round conduit in the hole to prevent possible damage to the cable?
Thanks. I always blow out the plaster.
Making good with Gyproc Easi-fill ftw
Yes.
