i used 4" Concrete screws to do all mine, Very Strong, Simple to .. drill hole through battens, then use 6mm or 6.5mm masonry bit to go through concrete then just screw into place, battens dont budge using these. Got mine from local pvc place £9 for 100 with hex bit and drill included
express anchors are brilliant but not good for battening a wall that is not totally flat as they pull the batten into all sorts of shapes and they are a bitch to get back out if you need a bigger packer in there to level it all up.
No not tried them, are they any good? They screw in i assume?
The express anchors are great for securing timber that will never be coming off again like wall plates for hanging joists off etc. Very fast but your arm ain't half pumping by the time your done with a large section!
