OK thanks all. I have had some useful advice here. I'll get service ducts in first and that gives me flexibility to get right cables in when it comes time for it.
thanks
thanks
It is. And the "Y" in "DIY" stands for.....?
I don't know if it is true, but I have been led to believe that "DIYnot" came about as a contraction of "DIYYnot" - a.k.a. (phonetically) "DIY - Why not?".[... it's called DIYnot. This is a (slightly) clever play on words, the idea that ostensibly one is doing the work oneself, yet in effect, they are not ...
2.5mm will not be suitable for 20A over a 30m length, more like 10A maximum.although I will probably need to use a waterproof FCU at the gate pillar to protect the lighting circuit from the 2.5mm cable. I understand that if I make this 2.5mm supply from the garage a radial then it can support up to 20amps.
Might as well go with 6mm² - the difference in cost will be marginal. Better to have 6mm² and find you only ever needed 4mm² than to have 4mm² and find you needed 6mm².he recommended at least 4mm or even 6mm SWA from consumer unit to gate pillar.
Suggest you ask people to quote on the basis of splitting the meter tails and coming off a switchfuse, rather than the house CU.He also said I could take 6mm from consumer unit MCB
That might be worth supplying yourself - start looking on eBay for a bargain, they turn up quite frequently. Alternatively, if you've not built the gate pillars yet, incorporate a flush box like the ones used for gas/electricity meters as long as you're sure you'll never want to leave things plugged in, as you won't be able to close the door. If you get a surface mounted enclosure with a removable gland plate in the base you could have cables coming out of that and still keep the door shut. Might be useful if you have lit-up stuff at Christmas. Whatever you use, make sure it's large enough to contain a small CU, a few sockets (which might have wall-warts plugged in), and any of the gate equipment you want in there. As with the cable, too big is better than too small.to the gate pillar cabinet
Many of the things sold as "garage CUs" are of poor quality. Ask your electrician to supply a good quality IP rated one from a mainstream brand with a range of commercial/industrial products. Have more than 2 circuits in case you need power tools for gate maintenance, and specify DP breakers.and fit a small garage type consumer unit which has a 30mA RCD and a 6A light and 20A non-light MCB to supply the light and gate and sockets on seperate protected circuits
The motors will take a lot more current when they start and will do so until they are rotating at the normal speed. ( unless they have expensive controllers that limit the current. ) The power may be 4 times the rated power while the motor is accelerating.
The duration of the high current shouldn't last more than a second or two and the cable will not be damaged. BUT the volt drop along the cable during the high current period may cause problems.
Also consider a back up battery for when there is no mains power. Releasing a gate driven by an under ground motor during a power cut can be a difficult and messy job. On a long drive the battery can be used to power the gates and be trickle charged between the gates being opened or closed. This then enables a smaller cable to be used along the drive and removes the voltage drop problems.
