isnt he allowed to carcass the install himself with a corgi god doing the final connection ?
In a word - NO!
doyle said:yes your right although it does read as though its about plastic or atleast i thought i saw plastic mentioned.
yes he is able to carcass it and have it tested by a corgi, anyone can install gas provided they are competent ie plumb dumb can install but not charge labour, the tester can then charge for it and divvy up later on the shhh
what is competent so corgi will try and say someone who has passed acs, legally anyone can provided there are no leaks/defects breach of regulations as the any of teh above would prove to be incompetent so if mr dumb installed and all was ok with it free from labour then mr corgi cant do jack 5hit about it as they would have to prove it to be incompetent.
thats why they passed the buck by stating must be free from labour charges, aint nothing special about 15mm copper for gas and 15 mm copper for water, hence further legal parametres of not allowed to make final connection as it presumed to be immediate gas.
So it's OK to lie and manipulate to get what you want out of someone?scatmanjohn said:Ring the number and tell them whats been going on and tell them you think you got a slight wiff of gas as you was walking past the house.
Then just wait for the transco van to pull up (very quickly so don't blink).
Softus said:So it's OK to lie and manipulate to get what you want out of someone?scatmanjohn said:Ring the number and tell them whats been going on and tell them you think you got a slight wiff of gas as you was walking past the house.
And what if it turned out that you'd been wrong, and that you'd acted hastily, and that an explosion occurred somewhere else as a result of you falsely diverting attention away from a deserving problem?scatmanjohn said:If you considered yourself/family/property to be in danger, then .....yep
Softus said:And what if it turned out that you'd been wrong, and that you'd acted hastily, and that an explosion occurred somewhere else as a result of you falsely diverting attention away from a deserving problem?scatmanjohn said:If you considered yourself/family/property to be in danger, then .....yep
I'm not advocating a failure to act, just taking the right course of action instead of the wrong one.scatmanjohn said:Yeh but...no but...and what if it turned out your suspisions were correct but you failed to act upon them and you and your children died a horrible death under HUGE pile of rubble that you once called home.
I get the feeling that you're being deliberately obtuse
Okey dokey - it was only a feeling. Sorry for that - no offence meant.scatmanjohn said:You have misread the tone of the post (i admit i have had a few cans though)
