Ronnie, You are one of the few armchair bricklayers whose post we will reply to.
We stopped using solid joists 6 years ago. We now use eco or easi joists, occasionally TJIs.
Going back to solids. We normally used to herring bone, (all as our first post). when joists were pitched. The way we were taught many years ago we can cut and fix herring bone as quick as solid bridging. That’s another story.
Whilst you have a valid point in what you say there is a flip side to the coin.
If you are dealing with a decent timber company, you should be buying in joists with 18to22% moisture content. Even though you crown them and sheet them the moment they arrive, you never know what sort of walk about they are going to take once pitched, therefore to avoid this we bridge them solid with timber or bones as soon as pitched to avoid them going down a one way street.
Yes, you may have shrinkage but moisture content will not go down to say 8to10% until unit is finished and some heat on
QUOTE RON But…solid blocking, shrinkage of the joists will loosen the blocking, so better to insert blocking once shrinkage of the joists (and preferably blocking too) has taken place.
That would be nice in a perfect world Ron, but at what stage do you think joists stop shrinking when there are possibly no windows or doors in the unit, no heat, and wet trades to follow.? There will be no shrinkage in the length of blockings, minimal shrinkage in the width of joists, the main shrinkage is in depth. So how long do you hang yourself on a coat hanger in the airing cupboard waiting for the joists to stop shrinking? Think about it Ron.
QUOTE TIM00 agree, and might mention a sometimes practice of carpenters in the USA.
Pleased to see you mentioned a SOMETIMES practice in Disney land. Good to know that the rest of them know what they are about
QUOTE TIM 00 .Another technique, which i've seen here and over there, is for a nailer ( 2 x 1 ) dropped across the tops of the joists ( esp. engineered joists ),
That’s a sign of a decent chippie to lay a centre brace. It is also mandatory with TJIs in the UK to comply with H&S, although to be honest we do not bother these days as we floor out the joists at the same time as pitching to avoid a lot of overhand blockwork.
Regards oldun
