What tools are necessary/helpful for self-leveling compound?
14 Jul 2013
British Columbia
A few years ago I applied SLC to a 30 square foot area using LevelQuick RS (Rapid Set). It ended up setting while I was still trying to encourage it to spread evenly, which resulted in a bit of manual fill after.
I'm going to tackle a larger area, about 160 square feet, and I'd like to avoid the mistakes I made the first time around:
1) I bought the LevelQuick ES (Extended Set, with 15 minutes of working time vs 5 minutes with the RS)
2) I'd like to use something better for helping to spread around the SLC. I have seen a few different products:
a) Trowel
b) Spiked Roller
c) Gauge Rake
d) Smoothing Paddle
e) Spiked Shoes
The gauge rake and smoothing paddle let you work standing up, looks easier and faster ( http://youtube.com/watch?v=BY3C8TWkwQw ).
Another video recommends using the spiked roller to release any trapped air bubbles and to blend SLC pours ( http://youtube.com/watch?v=g4auCNQWu-M ).
Does anyone have any experience or suggestions as to which tools to use? I'm a complete amateur, so would like to make this as easy as possible. But, I'd also like to avoid buying these tools if they're not that necessary.
What you laying ontop?
You will be ok with the trowel and spike roller.
Make sure you prime the floor as that will help with the flow of the screed.
Thanks for the feedback dazlight.
I will be placing Trafficmaster Allure Ultra/Clic Vinyl Plank Flooring on top. The specs allow 1/8" difference over 4'. Two of the room's walls are on the edge of the foundation, and parts of the concrete slab have settled about 3/8" below the foundation edge at the point where they meet.
I will prime with the primer recommended for the product.
