what type of chimney do i have what can i do with it?
1 Apr 2012
Staffordshire
My 1962 ex council house had one of those horrible wall hung gas fires in it when I moved in which was swiftly removed and replaced temporarily with an electric fireplace, I'm not getting ready to fully re-do my living room including the fireplace.
I haven't decided yet but thoughts are either a normal inset gas fire with surround, a multi fuel stove inset into the chimney or a gas fire made to look like a log burner.
my house appears to have two chimney pots one appears to be an open fire type probably from the kitchen but this is blocked off, and a gas terminal on the other this would be from the old gas fire.
so my question is what options do I have with this:
//media.diynot.com/186000_185711_74264_63615872_thumb.jpg
//media.diynot.com/186000_185711_74265_75493483_thumb.jpg
//media.diynot.com/186000_185711_74266_18699982_thumb.jpg
I'm guessing there isn't enough room to stick a new fire in there so it would need knocking out, would I then need a flue liner if I install a class 1 gas fire?
If I wanted to install a log burner I'd need more depth and would probably end up going into the old kitchen fireplace area, I guess I could just block up one chimney and use a flue liner for this?
Also the gas supply pipe used to sit infront of the chimney breast so I would drop this through the wall and link it to the back of the gas fire?[/img]
Just to add all I would be doing would be opening up the fireplace, I wouldn't be involved in connecting any appliances or sealing anything up or testing it as I'm not qualified in anything related.
hi sorry to bump but can anyone help?
the old fire had a sealing plate over the opening and a letterbox size slot through it, obviously an inset fire would need to go into this space so I don't know what my options are.
