We replaced some lighting in a warehouse when they re-racked and altered it around. We utilised many of the the same feeds, but installed new lighting trunking and fluorescents.
8 rows of trunking, 12 6ft twin fittings on each row, each wired alternately so if there is a fault only 50% die in the aisle, and just 50% can be switched on during the day as the warehouse is pretty light from the skylights.
Only a few months old, and two circuits tripped, 50% in one aisle and 50% in another aisle. Both circuits meggared absolutely fine to earth, could not feesably check L to N.
Both circuits re-energised and lasted for a good week until we got the next call, again, the same two circuits out. They couldn't tell us when they had failed.
Meggared both again, to earth both fine. Decided to split the circuits in half to prove which half was causing issues. The fittings are high frequency T8's.
Any guesses at the final outcome?
