What's The Strongest Screw To Not Rip Out Of Laminate?
4 May 2016
I need to screw something to the bottom of a laminate kitchen worktop being used as a 2.3m wall-mounted computer desk.
The screw needs to be long enough to get through one of these (width ways - through the 50mm section), then far enough into the 40mm laminate worktop from the bottom:
Underneath will be mounted one of these:
Which weighs 7kg.
Looking at it now I might have to attach at least 1 leg to the middle of it because of the weight?
Anyone have any better ideas? Is it even possible to mount something so heavy to a laminate worktop? It's not just the weight of the product but also the enclosure it will slide into... which will consist of wooden battens and an outer plywood slide-over box.
Thanks guys.
